interesują mnie rezultaty... z ca18det zbyt duzo sie nie da wyciągnąć (mnie interesuje cos ok 650-700PS)
zeby tracic przyczepnosc przy 250km/h robiac piekne burn outy !!ODINN pisze:co, nie da sie 700ps wydymac z CA ?![]()
pewnie ze sie da- $$$$$
Takie projekty juz jezdza, zobacz np na sxoc.com. mocowania silnika inne itd
Tylko powiedz mi... jezeli stac cie na RB30...
PO JAKA CHOLERE PAKOWAC TO DO S13 ????![]()
no dobra...zeby tracic przyczepnosc przy 250km/h robiac piekne burn outy !!
Bo ogólnie nie wychodził seryjnie, to jest blok z silnika RB30E (na jednym wałku wychodziły) ze Skyline R31 i głowica z RB25 czy RB26, ogólnie cały silnik to hybryda.tery pisze:poniewaz jestem CIEMNOTA, to czy ktos, prosze moglby mi napisac gdzie wystepowal rb30dett??? do dzisiaj nie wiedzialem ze takie cos istnieje...
RB30 and RB31
The ultimate upgrade for your RB26, these complete pre-assembled bottom-end kits are rated to handle power outputs up to 1400hp.
The RB30 features 86mm stroke with a forged chrome-moly crank, forged chrome-moly SCM steel H-beam conrods and forged 4032 aluminium 86mm pistons. It is made using a new Nissan block and specially designed spacer and liner kit.
Special features not found in a normal RB26 include an 8-bolt flywheel pattern*, 22mm gudgeon pins and 23mm rod bearing width. Nismo black metal crankshaft bearings are used, with specially designed crank cap bolts. The bottom end is supplied complete with a metal head gasket, specially designed head stud bolts, adjustable timing gears, tensioner pulley and longer timing belt.
The RB31 features 88mm stroke and can also be supplied with 87mm pistons for 3.2 litre capacity. Normal combustion chamber volume comes to 10cc, but specially shaped pistons can also be custom-ordered. The RB31 is built using an N1 block, with the same specially-designed spacer and liner arrangement as the RB30, with an oil restrictor and piston cooler jets already fitted.
OS Giken RB30 $27,000
OS Giken RB31 $28,500
Dj_Cube21 pisze:widziałem skyline'a r34 gtr z rb30dett (2xt28rs 1,1bar)(AWD) tylko na skyline'a mnie nie stac. sa stosunkowo drogie + przekładka kierownicy bo u nas ciezko to dostac. znacznie łatwiej o silnik (z przeniesieniem napedu na awd w nysie s13 chyba nie powinno byc wiekszych problemów
mocowania sa takie same czy inne?
