malyopis tej sil80 z prime
June05-
1989 Nissan 180sx
CA18det
Pearl White
6sp Manual
Power: 552rwhp @ 1.9bar (VP109)
TOMEI Stroker Kit
TOMEI Pistons
TOMEI Crank
TOMEI Rods
TOMEI 270 Cams
TOMEI Valve Springs
TOMEI Metal Head Gasket
Q45 Infinity Throttle Body
SARD 770cc Injectors
SARD Adj Fuel Pressure Regulator
SARD Radiator Cap
SARD Battery Shift Case
TRUST Front Mount Inter Cooler
TRUST High Mount Manifold
TRUST 50mm External Wastegate
TRUST T67-25g 10cm Turbine
TRUST Air Filter
TRUST Dump Pipe
TRUST Radiator Cap
TRUST Oil Cooler
TRUST BOV
KOYO Tripple Core Radiator
TRUST Oil Filter Relocator Kit
PRIME GARAGE Intake Plenum
PRIME GARAGE Titanium Front Pipe
PRIME GARAGE Titanium Exhaust
PRIME GARAGE Battery Relocation
PRIME GARAGE Surge tank
PRIME GARAGE Custom Cold Air Intake
PRIME GARAGE Oil Catch Can
MOTEC M4 Pro Stand-alone ECU
SPLITFIRE coilpacks
B&M Lauch Control
BOSCH External 044 Fuel Pump
BOSCH External Fuel Filter
NOS Direct Inj System
Vertex Front Bar
Trial Side Skirts
Trial Rear Bar
Monster Carbon Bonnet
Bonnet Pins
Perspex Rear 1/4 Windows
Perspex Rear Window
Square Headlights
GTR 2-Slate Grill
Stickers
16" x 8" White TE37 Wheels
Ganador Side mirrors
TRUST 6sp Straight Cut Sequential Gearbox
TRUST Carbon Propellor Shaft
TRUST Gear Indicator Display
APEXI N1 Drag Coilovers
APEXI N1 Camber tops
TEIN Castor/Tension Rods
CUSCO Carbon Front Strut Brace
CUSCO Carbon Rear Strut Brace
CUSCO Front Swaybar
CUSCO Rear Swaybar
CUSCO BMC Stopper
URAS Rear Subframe Bushes
Complete 5 Stud Conversion
AP RACING 4pot Front Brakes
AP RACING Braided Brake lines
R33 GTR Front Rotors
OS GIKEN Twin plate Clutch
OS GIKEN Lightened Flywheel
JUN Rear DRAG susp / members
JUN Rear Upper Camber Arms
NISMO 2-Way Mech LSD, 4.1 Ratio
MOMO Steering Wheel
BRIDE Brix II Suicide Seat
BRIDE Brix II Driver Seat
SABELT Seat Harness
SAFETY 21 Half Cage
ORIGIN Carbon Fibre Moulded Rear Seats
5" Tacho
Boost Gauge
Wide Spec Rear View Mirror
NOS Adj Switch
TRUST Shift Knob
Carbon Fibre Dash Surround
Carbon Fibre Ash Tray
Carbon Fibre Double Din Cover
po glebszej analizie juz ten sx nie jest najmocniejszy bo NORISS ZROBIL PONAD 600 KONNEGO I PANOWIE ZE SZWECJI 641HP WYDUSILI BEZ NITRO
jezeli o tego ci chodzi to niejest to najmocniejsze na swiecie tylko w usa 489hp
http://images.google.pl/imgres?imgurl=h ... pl%26lr%3D
http://forums.nicoclub.com/zerothread?id=351415 nie o tym mówiłem ;]
ps podklep jakiegos linka bo nie moge znalesc tego o którym mowisz a bym z chcecia obejzał
