AirRatio turbiny
: sob 11 paź, 2008 17:02
autor: TiGRA
Siemka
Zastanawiałem się ze Scooterem o co tak do końca biega z tym AirRatio wytłoczonym na muszli wydechowej/ssącej turbiny.
Patrzę i widzę AR 0.64 (na przykład).
No i tu zaczyna się łamigłówka :D
W jakiej jednostce miary jest podawane AR??
Doszliśmy do wniosku ze Scooterem, że im większe AR muszli wydechowej tym większy lag.
Z mojej wiedzy AR wydechu ma wpływ na prędkość obrotową wirnika co przekłada się na stopień sprzężenia na muszli ssącej.
Ma ktoś wiedzę w tym temacie?
: sob 11 paź, 2008 18:00
autor: BloodS
Understanding housing sizing: A/R
A/R (Area/Radius) describes a geometric characteristic of all compressor and turbine housings. Technically, it is defined as:
the inlet (or, for compressor housings, the discharge) cross-sectional area divided by the radius from the turbo centerline to the centroid of that area (see Figure 2.).
The A/R parameter has different effects on the compressor and turbine performance, as outlined below.
Compressor A/R - Compressor performance is comparatively insensitive to changes in A/R. Larger A/R housings are sometimes used to optimize performance of low boost applications, and smaller A/R are used for high boost applications. However, as this influence of A/R on compressor performance is minor, there are not A/R options available for compressor housings.
Turbine A/R - Turbine performance is greatly affected by changing the A/R of the housing, as it is used to adjust the flow capacity of the turbine. Using a smaller A/R will increase the exhaust gas velocity into the turbine wheel. This provides increased turbine power at lower engine speeds, resulting in a quicker boost rise. However, a small A/R also causes the flow to enter the wheel more tangentially, which reduces the ultimate flow capacity of the turbine wheel. This will tend to increase exhaust backpressure and hence reduce the engine's ability to "breathe" effectively at high RPM, adversely affecting peak engine power.
Conversely, using a larger A/R will lower exhaust gas velocity, and delay boost rise. The flow in a larger A/R housing enters the wheel in a more radial fashion, increasing the wheel's effective flow capacity, resulting in lower backpressure and better power at higher engine speeds.
When deciding between A/R options, be realistic with the intended vehicle use and use the A/R to bias the performance toward the desired powerband characteristic.
Here's a simplistic look at comparing turbine housing geometry with different applications. By comparing different turbine housing A/R, it is often possible to determine the intended use of the system.
Imagine two 3.5L engines both using GT30R turbochargers. The only difference between the two engines is a different turbine housing A/R; otherwise the two engines are identical:
1. Engine #1 has turbine housing with an A/R of 0.63
2. Engine #2 has a turbine housing with an A/R of 1.06.
What can we infer about the intended use and the turbocharger matching for each engine?
Engine#1: This engine is using a smaller A/R turbine housing (0.63) thus biased more towards low-end torque and optimal boost response. Many would describe this as being more "fun" to drive on the street, as normal daily driving habits tend to favor transient response. However, at higher engine speeds, this smaller A/R housing will result in high backpressure, which can result in a loss of top end power. This type of engine performance is desirable for street applications where the low speed boost response and transient conditions are more important than top end power.
Engine #2: This engine is using a larger A/R turbine housing (1.06) and is biased towards peak horsepower, while sacrificing transient response and torque at very low engine speeds. The larger A/R turbine housing will continue to minimize backpressure at high rpm, to the benefit of engine peak power. On the other hand, this will also raise the engine speed at which the turbo can provide boost, increasing time to boost. The performance of Engine #2 is more desirable for racing applications than Engine #1 where the engine will be operating at high engine speeds most of the time.
Niech ktoś to tylko przetłumaczy :P
A to link jakby co: http://www.turbobygarrett.com/turbobyga ... ch102.html
Pozdro
[ Dodano: Sob 11 Paź, 2008 19:03 ]
No i A/R nie znaczy AirRatio z tego wynika :P
: sob 11 paź, 2008 18:37
autor: cypher47
trochę z innej strony chciałbym zacytować część artykułu z pewnej "najlepszej" gazety traktującej o szeroko pojętym tuningu:
"Stosunek A/R"
Wartość A/R - stosunek powierzchni wlotu do promienia obudowy muszli (Area/Radius).
Im większy tym większy A/R tym większa pojemność turbiny, większy przepływ spalin i większy LAG. Duży A/R pozwala osiągać większe moce w stosunku to turbo z mniejszym A/R, ale kosztem szybkości reakcji"
Później jest cała masa herezji, których nie chcę cytować... :534:
Re: AirRatio turbiny
: sob 11 paź, 2008 18:57
autor: roball
TiGRA pisze:Siemka
Jest to wartość bez jednostek - ważna jest proporcja,
choć z rachunku jednostek wynikają metry ... (powierzchnia przez długość)
do tego ważnym pojęciem jest trim wirnika - czyli geometria łopatek - im bardziej strome (ostrzejsze) łopatki tym mniej oporu wirnik stawia..
czyli im większy trim tym wyżej turbina bierze (i później się zapycha) ..
ważne żeby trim był idealnie zgrany z AR muszli ...
: ndz 12 paź, 2008 14:00
autor: TiGRA
Nie no panowie... po bandzie poszliście... :mrgreen:
MEGA DZIENKS DLA WSZYSTKICH!!!
Ale będę teraz uczony... :D
